Ana içeriğe geç
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
ipad 2 - My screen is blue after falling.
Hey guys, i dropped my ipad 2 on a carpet from 45cm. it has a screen protector but now my screen is blue but i can still see and interact with the display. (see photo)
what do i have to check if it is broken or what do i have to change?
(maybe the lcd or the display cable or the graphic chip?)
i have an ipad 2 with wifi and cellular, 64gb.
please help me :) and sorry for my bad english.
Paul
Bu iyi bir soru mu?
Puan 2
2 Yorum
It's a hardware issue. You need to go to the Apple store. By the way, there is other method to fix iPad blue screen of death. But the way can't solve hardware problems.
How to Fix iPad Blue Screen of Death
tarafından
So basically what you want to do if it’s all blue and there is no apps, you want to hold the power button for 10 or so seconds. If it does not restart then I suggest you take it to the Apple store. Also try to make sure everything was saved usually it is but you should make sure,
tarafından
Yorum Ekle
8 Cevap
Filtre ölçütü:
Seçilen Çözüm
First try a hard reset by holding down the power and home buttons together for 10 seconds or so. If that doesn't work try giving the back of the iPad a firm smack. There have been cases where a fall like this jars the LCD cable loose and a firm hit to the back sets it back in place.
Bu yanıt yardımcı oldu mu?
Puan 16
20 Yorum:
Totally worked!!!!! So excited!
tarafından
this totally worked. Thank goodness.
tarafından
Crazy, but it worked.
tarafından
Crazy, but it worked. Meaning the smack worked.
tarafından
It worked! Your answer saved me.
tarafından
15 tane daha yorum göster
Yorum Ekle
You may need to open it up and re-seat the LCD cable. See this guide.
Puan 3
1 Yorum:
The sack worked awesome thanks
tarafından
Yorum Ekle
LIke David and Brian suggest, this is the LCD connector. Smack will resolve it for awhile, but for a lasting repair open it up and reseat the connector.
Puan 2
Yorum Ekle
I was working on one that did this without dropping it. The display did not show except for a flash when you press the wake/sleep button. I did the bump method on it after some research. It recovered to full bright clear display, then I opened it up and replaced the LCD cable and sealed it with Kapton tape. The cable was probably not bad but it was not expensive so I replaced it anyway.
Puan 1
Yorum Ekle
The smacking it totally worked! Thank you!!
Puan 1
Yorum Ekle
I tried this also with mine after I dropped it and everything went red on mine...After the hard reset didn't work, I re-dropped it several times and it fixed the problem........thank you for the info......
Puan 1
Yorum Ekle
Just smacking the back haphazard will probably not fix the problem. You will need to smack it about four inches fro each side in the corner where the volume control is. That is where the connector is and smacking anywhere else will probably not work.
Puan 0
Yorum Ekle
Yes, it worked for my ipad2. I just hit few times at the back side of ipad and it is working fine now.
Puan 0
1 Yorum:
Thannnkkk youuuuu...the smack totally worked.
tarafından
Yorum Ekle
Yanıtını ekle
Paul sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 32
Her zaman: 45,271
