Ana içeriğe geç
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Soru Tümünü görüntüle
It was dropped and has a broken hinge pin from the display!
The display still works but the drop broke the left hand hinge pin out of the display; snapped the cheap pot metal and all. Am I stuck buying the entire display assembly. This is still in warranty but of course they won't cover this!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If you've broken the frame (which is Aluminum, not pot-metal) then the frame must be replaced (a major DIY project). If you've broken a clutch (Apple speak for hinge) that would have to be replaced. If you've also damaged the Display cover that too would need replacement.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
gunug sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 117
