Well, that’s not the point anyway. We’re trying to fix an issue here so here are the ways, in which you can try to fix your iPhone that keeps shutting off, restarting or freezing.
Turn ON/OFF Cellular: As strange and absolutely impossible as it sounds, I’ve seen people get this issue sorted out by turning off their cellular data and then turning it on again. Arguably, this doesn’t work everywhere. But since this is the most simplest thing you can try, you should begin here. Don’t believe me? To do so go to settings → Cellular/Mobile → Turn On/Off Mobile Data.
Reboot iPhone: To reboot your iPhone, hold the power button and home button simultaneously for a few seconds. The Apple logo will appear on the screen and your iPhone is rebooted.
Reset iPhone: To reset your iPhone, go to Settings → General → Reset → Reset All Settings.
Faulty App: No matter how strong and protected the App Store is said to be, there are apps that aren’t really good for the health of your iPhone. One of these, possibly, could be ruining your iPhone experience. Did you download any new app that triggered the issue? It doesn’t matter if it’s a popular app or an app that no one has ever heard of. Just try deleting it.
Delete the app → Reboot your iPhone → Sync with iTunes and see if this sorts the issue.
Restore From An Old Backup: No luck yet? Try this method (it’s tougher if you’ve got an iPhone that keeps restarting too often). Connect your iPhone to iTunes on the system and then restore from an old backup. In case you got lucky, things will be back to normal.
Recovery Mode + Restore: This could be the best possible solution you could ask for. Again, it’s tougher to implement if your iPhone keeps shutting off or rebooting every two-three minutes.
Hope it can help you https://support.apple.com/en-us/HT203899
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
same problem and battery percentage stays on 100% doesn't change.
and when i look at diagnostics on the device i got a ton of panic msgs and reset counters and stuff.
elias tarafından
Help me plz that happen to me how can I fix it
victorkenny140 tarafından
Hi, my mobile batarry was low and it's discharge itself but now it's not charging please suggest what should i do
ravirajbodhgaya1 tarafından
my iPhone 5 keeps restarting and i had noticed it was the battery and i took it for replacement but after few days the issue came back again it keeps restating and crashing the ios every time it crash i have to restore again . and i dont know the problem plz help plz
maxmac suppliers tarafından
chillax bruh...
Enable ur data in
Settings -----> Cellular-----> Enable cellular data and 3G
Shutting down your iphone.....
Taking out your Sim Card
switch on and wait until 15 sec (this is normal for all electronic to become natural...
Switch off
Put your Sim like normal...
Switch on....
If still facing this issue just upgrade your IOS (this is not to be an issue)
else if still happen / wrong
Change your battery...
if still not working that might be the internal issue (serious issue)
u can send it nearest Rubbish bin. Thanks
#malaysiahackingcrew
#weareprogrammer
#lagcodes
#anon_cod3r
#hackurlife
#humanity
#love
#stopkillingpeople
phantom Nuker tarafından
27 tane daha yorum göster
