Ana içeriğe geç
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Soru Tümünü görüntüle
Fan not working on second HD in iMac?
Hi. My iMac is a i5 model, I have a second hard drive installed and installed MS Windows 8.1 with bootcamp.
When i use Windows the fan will not go on. I installed Speedfan and it shows the video card processor and hard drive, but no fan. Is there any way can i make the fan go on on the second HD of windows.
Thanks
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Vito,
There is a a dedicated fan for your main hard drive and also a fan for the optical drive. In both cases these fans are controlled via SMC services in your system. The SMC services are not accessible via MS windows but accessable via Apples OS-X.
This gets into the API's and how they are accessed via the OS. If you give this application a try running under OS-X Temperature Gauge Pro you will see the fan & thermal sensors, unlike Speedfan which can't access the OS-X API's.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Temperature Gauge is ox appl. the speedfan i install is for windows, i can see any fan on windows when i run speed fan? that i have installed on the 2hard drive. with bootcamp no os.
tarafından
Correct Temperature Gauge is a OS-X-application and needs to run with OS-X. Speedfan can't access the needed OS API's to see the fans. SMART services are within the hard drive and don't have access to the system hardware.
tarafından
ok, i try and see if works, like u said … thanks
tarafından
Yorum Ekle
Yanıtını ekle
vitodeluca sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 107
