Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Soru Tümünü görüntüle
Why my iPhone 4 is not booting after touch ic soldering?
This iphone had a problem with the touch screen.
The problem came from the motherboard, because with another screen, it still didn't work.
Since I already repaired an iphone 4s with a faulty touch ic, I thought changing the touch ic on this iphone 4 would fix it.
Problem is, I apparently overheated the motherboard and it does not start.
Here are 2 pictures of the overheated area.
Is there anything I can do to know what is damaged ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Pegston39, the images are not quite as clear, but it sure looks like you got plenty of heat and melted plenty of stuff. Looks to me like you are in for a new logic board. To evaluate all the damage, I suggest you remove all the EMI shields, wash your board with isopropyl alcohol and a soft brush. After that, add a few more high res images of your board to your original question.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Pegston39 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 121
