Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Soru Tümünü görüntüle
My vibrator and proximity sensor is not working
Hey
My friend gift me one iphone with broken display and proximity sensor, so i bought one from ebay and i assembled it, but the sensor is still not working.
Also i recently noticed my vibrator was not working and so i removed another from dad's iphone and used it but still nothing
im from italian, sorry for my english :)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Cut two hole out of the electrical tape and place over the sensors
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
but it is weird because if i tap it with finger light should not pass
tarafından
Look I'm giving you advise that is tryed and tested and works if you choose not to take that advise no problem
tarafından
If you have changed the vibrate motor and it's still not working you need to change the volume , mute and headphone jack flex that's were the vibrate motor gets it's power from.. As for the proximity not working it's possible that to much light is getting in and causing the sensor not to work .. I simply use the electrical tape trick to fix this
tarafından
what is that electrical tape trick ?
tarafından
im not saying it is wrong :) i just want to be sure it is not anything else before disassembly the iphone again
tarafından
Yorum Ekle
If the proximity sensor still isn't working, you may need to replace the power button and sensor.
While you've got it open you may want to replace the vibrator with a brand new one. iFixit has them for only $9.95
iPhone 4 Vibrator Görseli
Kılavuz
iPhone 4 Vibrator Replacement
Zorluk:
Orta
20 - 40 minutes
iPhone 4 Power & Sensor Cable Görseli
Kılavuz
iPhone 4 Power & Sensor Cable Replacement
Zorluk:
Zor
1 - 2 hours
Puan 0
1 Yorum:
i already tryed one working vibrator but still not working
so about power sensor i need change cable? hm it looking hard this part
thank you for the rapid ansewer :)
tarafından
Yorum Ekle
Yanıtını ekle
Nikkolo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 201
