Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
no sound while recording video
If I'm correct the upper mic is the one that records the sound for videos and the speaker during calls.
This mic is not working. What can I do to fix this?
The mic works perfectly during calls (no speaker), while recording audio on whatsapp, and recording voice memos. So I know the problem is the upper microphone and not the lower microphone.
How do I fix it?
Thank you.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
7 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I have had this issue three or four times, usually after I installed an app like voice recording, or recently, streaming radio. So far, rebooting has almost always fixed it. Once, I did have to delete the offending app.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Here also: no sound on recorded video. Turn iPhone 4 off/on fixed it.
tarafından
Yorum Ekle
The iPhone 4 has this as a common issue and most of the time it can be fixed with a simple hard reset.
Puan 1
Yorum Ekle
The Proximity Flex cable for the GSM iPhone 4 contains the top mic, so if that is your problem changing that flex cable should solve the issue.
Puan 0
Yorum Ekle
What joseA said the upper mic is located on the proximity sensor replacing this will sort you out
Puan 0
Yorum Ekle
https://www.youtube.com/watch?v=Fvtxp8Va...
Check out this video 100% solution easy without tearing apart your iphone !!!
Like if it worked.
Puan 0
Yorum Ekle
I used to use my iPhone 5s to record a show. Even though the show was extremely loud, my phone still couldn't record any sound. I searched the internet and found one answer: tear off the plastic cover on the back of the phone. I found there was a tiny hole besides the camera, which I assume it's where the audio inputs. I did record sound ever since I tore it off.
Puan 0
Yorum Ekle
hi,100000% change the dock connector,just done 2 iphone 4
Puan 0
Yorum Ekle
Yanıtını ekle
Mel Dominguez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 20,428
