Ana içeriğe geç
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Soru Tümünü görüntüle
Soru Kapandı
Identification of damaged components on MBP 5.1 Late2008 motherboard
MacBook Pro 15" 5.1 Unibody Late 2008
Please help me to identify damaged components on Macbook Pro Late 2008 motherboard. HD photos of this part of the board are also highly welcomed. If you have any please send these pictures to progresiv (at) list dot ru
Thanks
Bu iyi bir soru mu?
Puan 0
1 Yorum
sirob, use this guide Adding images to an existing question to add images. Lets see what else is going on with your board.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
sirob777 , the damaged parts are:
Reference designator C6208 10UF 15V 20% Tant-Poly capacitor in a 2012-LLp package
Reference designator C6320 10UF 15V 20% Tant-Poly capacitor in a 2012-LLp package
Reference designator C6853 10UF 15V 20% Tant-Poly capacitor in a 2012-LLp package
all of the caps are part of your audio circuitry. Hope this helps, good luck.
Update
the missing component is reference designator C6321 and its values are identical to the rest 10UF 15V 20% Tant-Poly capacitor in a 2012-LLp package
It is also part of your Line-in circuitry. Just wondering how you blew all those caps. Did you by any chance try to connect an amp or other device to the line-in
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks allot! Strange, but after all my laptop sill able to play music and movies sound tracks. It's just that Spinning pinwheel began to appear more frequently. That's why I started to dig.
It think that at the connector area (where C6320 pointing) there is two problems. One SMD plate is empty and one capacitor is damaged. I'll try to post picture which selected bits.
If you let me to ask you, what is the source where you take that info about all components? Do you have the schemes?
tarafından
I bet your line-in will give you trouble ;-)
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 351
