Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Soru Tümünü görüntüle
Gyroscope stopped working, no screen rotating, after rear case replace
Hello there.
For starters. I have an iPhone 5. I've replaced the power button on my iPhone, after that everything worked just fine - normally I have the standing position (portrait) locked, so the screen doesn't tilt when I'm laying in my bed. But then I found and old game that I used to play, this game is called Labyrinth, it's a game where a ball is moving the way you're tilting your phone.
But the ball stood still, I've tried to reset the phone back to factory - but it when work. I've tried to unlock the lock, so that I could tilt the screen into landscape mode, this doesn't work either.
I've tried to search for answers and I come up almost empty handed. The only thing I found out, is that sensor (gyro?) which picks up that the phone is tilting are located at the Logic Board.
I don't know when the sensor broke. Because I don't use it very much. I've read that it often comes because of you dropping your iPhone on the ground?
I came aware of the flaw after home button replacement.
The problem is that the tread was old and no one answered my question, which I'm now asking you:
- What can I try to make it work?
- Is there any cable of something I should try to take off an set it right back?
- What can I do to troubleshoot this?
- Is it possible to change that censor, on the Logic Board?
The only question is: What can I do to fix this?
Hope someone out there can help me!
Best,
Stefan
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hello,
I don't believe that you problem is a sensor. The problem sounds like the mute/ rotation switch is broken or may have been installed improperly. Do you have it set to mute or to lock rotation?
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I have this same problem. My iPhone 5s cannot play games with tilt controls, including VR. It absolutely sucks because I used to love using my VR headset and playing Temple Run 2 but now I can't
tarafından
Yorum Ekle
Yanıtını ekle
Stefan Bols sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 6,802
