Ana içeriğe geç
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
20 Soru Tümünü görüntüle
Not getting cold at all
We have a 10-15 year old fridge that we moved from our lake place to home. It worked perfectly before we unplugged it to bring it home. It sat in our garage for about a week, we then plugged it in and it won't cool at all. The light comes on inside, but it isn't getting cold. I don't understand because it worked perfectly before we moved it? Any help would be appreciated. Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
There are several possibilities the may be causing the problem.
Refrigerator's need to be on their on power circuit, if there is something else on the same circuit the fridge motor will not have enough power to run and may burn out. Or the outlet the fridge is plugged into may be bad. If you have a heavy duty extension cord you can plug the fridge into a different circuit, do not use a light extension cord it will not be able to handle the amount of power the fridge will draw and may catch fire.
If the fridge was laid on its back or side when it was moved the compressor may have been damaged.
The fridge is old the circuit board may have gone out, or the hard start capacitor may be bad. If the hard start capacitor is bad you should hear a clicking noise coming from the bottom of the fridge at the back.
Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thank you so much!
tarafından
Yorum Ekle
Evaporator Fan Motor
Puan 0
1 Yorum:
Thank you! We will check into this!
tarafından
Yorum Ekle
Yanıtını ekle
Tammie Rothenbuhler sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 155
