Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Soru Tümünü görüntüle
Broken gasket from home button
When replacing the home button gasket i noticed that there's still a very thin and even square of the old gasket attached. Should the surface be completly clean (danger of scratching the surface or removing only partialy) or is it safe to glue on top?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I take it your talking about the rubber gasket if yes then just use a little heat and pick off with tweezers and yes area should be clean
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I imagined that was the correct way to do it. I was just trying to avoid any possible problems during the ungluing.
Thanks.
tarafından
Yorum Ekle
Yanıtını ekle
Tiago Ferreira sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 74
