Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
YLOD Light Sequence Really Persistent
This is what i said to the IFIXIT staff and they recommended me to try the forums for some support from the public etc.
sorry to be a bother any help is of help.
I have followed the YLOD repair guide by MJ on the IFIXIT website and
the problem still persist's, the flashing red light is what remains
after this light sequence: Green,Yellow,Red Flashing, then i press the
power button again and it goes to a solid red light then i press it
again at the light sequence repeats i can hear the CPU Fan spin for
about 2 - 3 seconds then it cuts off i have my suspicion its the
motherboard :/ i have used Artic Thermal Paste 5 on both the CPU & GPU
and evenly spread it using the plastic card technique and followed the
PS3 disassembly guide from step 42 backwards to re-put everything back
together correctly please help me
Okay so i managed to do everything correctly like the video instructed the issue i get now is, the PS3 only stays on for about 3 minutes before the green,yellow,green,red flashing light sequence re-appears then when i press the power button again it just flashes red then goes a solid red so i press the power button again and it works for another 3 minutes. it only seems though to come on with the solid green light and blue light when i have used the heat gun for about 5 minutes.
can any one shed some light on my problem please >.< ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Jaysonbroome, first you do need to remember that this will only work if your YLOD is caused by solder fractures and if they are not to extreme. Reflowing any board with a heatgun is not an exact science and as such does have a certain amount of failure. The proper fix for this would most likely be a professional reball. Anyhow, the biggest reason for failure to reflow is not enough consistant heat. There is a fine line between reflowing and absolutely melting the solder, so one needs to be aggressive without going over board. If nothing else, get a couple of temperature probes and see what heat you generate. For a decent reflow you want to be between 225 and 235 degrees Celsius for about 90 seconds. You don't want to be above 217 degrees Celsius for longer than 3 minutes. Even a mediocre heat gun should accomplish that. You'll find a decent write up about a good procedure right here. Follow the guide from here and keep on trying. If at first you don't succeed....:). hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
It is possible the processors need reflowed with a reflow station. I warn all my customers that there will come a point in the life of the console that it is not repairable at my level (don't own a reflow station). Sometimes the board is too bad that a heat gun will not solve the ylod.
Additionally, if the ylod repair doesn't work the first time, I attempt it a second time. Give it a go again. Make sure you set your heat gun on high and get the target area good.
Puan 0
Yorum Ekle
Yanıtını ekle
Jaysonbroome sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 341
