Ana içeriğe geç
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192 Soru Tümünü görüntüle
Soru Kapandı
New Keyboard Installation - Select keys working
Hello iFixIt!
Earlier this year, I spilled liquid onto the Macbook Air. After around a day, when I pressed the keys it would just input weird character - not letters. Obviously it seemed like the keyboard was impacted but nothing else because once I plugged in an external keyboard, I can use the machine fine.
This morning I installed the keyboard perfectly, and re-assembled the Mac. Only a select amount of keys work "B, up and left arrow and one command"
I purchased this keyboard from eBay: http://www.ebay.com/itm/271346555131?_tr...
He has a 99.9% excellent rating.
What could the problem be? Is there another issue with the laptop? Did I receive a broken keyboard? Was it a poor keyboard installation?
Any help would be great!
Regards,
Kevin A
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Time and moisture=corrosion damage.
It's possible that the connector or other components on the logic board are damaged. Only you, by close examination with a magnifying glass, can determine this.
If there is no other damage visible talk with your vendor about the replacement keyboard.
If this answer is acceptable please remember to return and mark it.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thank you, I'll further investigate
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 114
