Ana içeriğe geç
A rotary tool made by the Dremel company. It is model number 395 and runs at 5000-35,000rpm.
Why is my device running at inconsistent speeds?
I plugged my device in and it will either turn on and run super fast or super slow and nowhere in the middle. How can I go about fixing this problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Yes, this problem can be fixed. Ways to fix this problem are to check the carbon brushes to see if they are worn out and replace them. If that doesn't work then check the TRIAC chip to see if it is faulty and replace it.
Dremel MultiPro 395 Troubleshooting
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Cheyenne Where would you find a replacement dremel 395 TRIAC chip at? What is that anyways?
tarafından
Yorum Ekle
Yanıtını ekle
Matthew Satton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 1,779
