Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Soru Tümünü görüntüle
iPhone 5 boots to Apple logo, then logo fades off then restarts
Hi everyone, I am having a very annoying issue with my phone. I have replaced the battery 2 times, with both working for some time. It would eventually turn into my iPhone working, but shutting off at random with the battery meter indicating 60% left. It was like that for a bit, but now my phone won't even get past the boot logo and it keeps restarting on its own. Goes apple logo, 10 secs later, the logo fades off then restarts all over again. Please help resolve!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 13
3 Yorum
i am having the same problem but mines have lines going down the screen
tarafından
Am having the same problem but with an iphone 6 plus
tarafından
I am having the same problem but mine keeps on changing colors
tarafından
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Take a look around this part just right of the battery connector see if any of the little components are missing like in the pic ere
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I do not know what you had tried so here is some things to try
- Hard restart (Hold power butten and home until apple logo appear)
- Turn on when connected to power
- When it is completely off, connect power
- Connect to iTunes and restore it
- Open it, disconnect the battery, wait 1 minute, reconnect it and reassemble the phone, plug into power
Puan 0
1 Yorum:
I have tried all of the above. The phone does not even get to the point of it being recognized by iTunes.
tarafından
Yorum Ekle
There's is a component on the motherboard called a U2 when this goes or is blown can cause this problem..
Puan 0
2 Yorum:
Oh no! :( is there anyway I can get it fixed? I had over 700 photos from a vacation trip that never had a chance to backup!
tarafından
Replace the chip
tarafından
Yorum Ekle
Take a look around your battery connector area you may have damaged some components that will cases a boot loop and for the battery percentage not to change much.
Puan 0
Yorum Ekle
Here's my story. I used the App Store app to check my battery health as it was draining too quick and it showed the health of the battery at 36%.
Got a brand new battery and changed it. Worked for a bit, then powered off. connected my external battery to charge and it turned on showing 95% charge already. Did what I needed to do, and put it to sleep, got in the car, plugged it in to charge and heard the ding sound of adapter being plugged in.
Got home (15min later) and it was off again. connected external battery, no joy. connected to computer, no joy. pressed sleep and home together for a while. no joy. pressed all 4 buttons for 2-5 mins, no joy.
Finally, took the new battery out and put old battery in, and finally got apple logo. it kept doing the reboot loop for like 10-20 mins, and then powered up showing 44% full.
At this point, i'm thinking, Whiskey-Tango-Foxtrot!!!!
The new battery, when the unit was on, showed 100% health with the App Store app, but no good after a random short amount of time being sleep.
Any ideas?
Puan 0
1 Yorum:
In-Case this helps, I just found out that the new batteries I was sold were iPhone5c batteries which won't work on iPhone5s.
>> iPhone 5c Replacement Battery
## Apple Part #: 616-0667, 616-0668, 616-0669, 616-0730, 616-0762, 661-8300,
** Does not work in iPhone 5 or 5s
>> iPhone 5s Replacement Battery
## Apple Part #: 616-0718, 616-0719, 616-0720, 616-0721, 616-0722, 616-0728,
** This battery is not compatible with iPhone 5 or 5c
So, when you get a new battery, look at the numbers on the Label and specifically the one in front of the tag [APN:]
I'm hoping i can get my money back or replacement with the correct model #
tarafından
Yorum Ekle
I don't know the technical answer but I'm pretty sure its a problem with the battery and speaking of today I'm going to CPR to get some top-of-the-line Macintosh Memory installed into my Asus notebook and my phone's battery not working wasn't planned so I'm going to see if a new battery would work :)
Puan 0
Yorum Ekle
Yanıtını ekle
danchhieu sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 32,250
