Ana içeriğe geç
Verizon tarafından 2006 yılında piyasaya sürülen bu çok yönlü kablosuz geniş bant yönlendirici, Ethernet ve Wi-Fi ağlarını destekler.
Why is my internet connection slow?
When I go to load a web page, it loads very slowly or even doesn't load at all. After checking all the connections to the computer and router, everything is connected properly. Why could this be?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
You might want to consider if any other electronic devices are interfering with your internet connection.
If your other electronics are working on the same frequency as your router, your webpages could load slowly. Make sure that you keep other electronics like cordless phones and microwaves away from your router to help it work efficiently.
If this trick doesn't work, you may want to check the device's Troubleshooting Page for additional advice.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
To piggy back on Jeffery Fox...I had similar issues and called my provider after trying sites like speedtest.net and found my connection was not up to snuff. Then we logged into my wireless router and discovered that a number of my channels were overused by other wireless systems nearby so we tested a few and tried the speed test repeatedly to pick what worked best. Occasionally, I have found a reset of the wireless modem helps refresh things to. Your mileage my vary...
Puan 0
Yorum Ekle
Internet speed test at: https://speedtest.19216811wiki.com/
Puan 0
Yorum Ekle
Yanıtını ekle
James Carby sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 19
Her zaman: 546
