Ana içeriğe geç
The HTC EVO is a Smartphone by HTC powered by a 1-GHz Snapdragon processor and runs the Android operating system.
Screen installation adhesive and procedure?
saw your teardown of the HTC EVO and since some of the EVO owners are experiencing screen separation issues..
Can you create a procedure with type of adhesive used to install a new glass screen?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
2 Yorum
Thank you for the guide, but I was looking for a adhesive recommendation and a technique for holding the glass down level under the bezel.
tarafından
I also what to know,it looks like a gasket the that holds it down.
tarafından
Yorum Ekle
10 Cevap
Filtre ölçütü:
En Yararlı Yanıt
That would be right here.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Glad to see those guides are coming in handy :)
tarafından
I have to say I was amazed to see them already there, the other day they weren't and I was directing people to the teardown. Good job on the quick work!
tarafından
Yorum Ekle
Bu cevap aslında başka bir soru için verilmişti.
Just be careful, I was kind of understanding that it is a display issue with the glass seperating, but I could be wrong. Why else did they stop using the one display and go to another as reported today on several sites like http://www.phonearena.com/htmls/New-EVO-...
Goog luck, I am returning and getting another one before my 30 days is up at Best Buy.
Puan 2
1 Yorum:
sorry you must not have understood me. I have 002, and I do not want 003. I want to know what glue is the best to use to glue down the screen on the phone I have. I cant get nor do I want an exchange. I am not scared to open the phone by any means. thanks for your response though. To answer your question htc stopped using the more expensive display to go with the cheaper one. The display has nothing to do with the screen separating from the phone its the faulty glue which for me is an easy fix if I know what kind to use.
tarafından
Yorum Ekle
Actually, I recently had to replace my evo with a newer one. I much prefer the newer screen. I believe the more "expensive" display you are referring to was the novatek screens, where as the "cheaper" screens are the epsons. In my opinion, while not quite as bright as the nova screens, the epson screens produce a much better color quality. For me, that is preferable in a screen. Others prefer the brighter nova which also seem to have a SLIGHT purply hue to the coloring.
Oh and just an FYI, your hardware info number eg. 002 and 003, does NOT automatically tell you which screen you have. There have been both nova and epson screens since launch with both screens being found on 002 and 003 revisions. Just check the android forums or xda. I won't go into how to tell which you have here, but there are plenty of ways to tell at the other sites.
Puan 1
Yorum Ekle
Use Jet glue slow jell. It isn't super slow but gives you a little time before it sets. That is, 15 seconds or so. As far as removing the old adhesive, a hair dryer should suffice.
Puan 0
Yorum Ekle
there is a website where you can get all the parts to this phone i actual just cracked my screen.. where sprint wouldnt replace it . Sorry #$$#@$& tried to get me to buy a new phone. But the screen was only 100 bucks on this website.. http://www.repairsuniverse.com/info.html
Puan 0
Yorum Ekle
Check ebay the gadgetfix store has it for $62 bucks.
Puan 0
Yorum Ekle
I found the Evo 4g installation adhesive sold seperately at
http://www.durapowerglobal.com/HTC-Evo-4...
and the replacement glass screen digitizer for $35
Puan 0
Yorum Ekle
Hey I have a Htc Evo 4g phone everything works but theres a problem with th screen sometime when I go to dial a number or some numbers to call it fails a the numbers in it start calling automatic.... Sometimes I what to text some patters in it do da same I touch letter j in it goes to k in some won't even tap... I want to know what's wrong in do I need to replace my screen?? Plz help ASAP
Puan 0
Yorum Ekle
jesus christ what a $$$^!%* mess this thread is. Great work with your SEO! Too bad the answer to my problem is nowhere near here!
Puan 0
Yorum Ekle
You can get adhesive from durapower global, check it out:
http://durapowerglobal.com/HTC-EVO-4G-Di...
Puan 0
Yorum Ekle
Yanıtını ekle
chris smith sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 18,487
