Ana içeriğe geç
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
455 Soru Tümünü görüntüle
What screwdriver should I use?
Hello there, I will be taking apart my 3DS ( Wifi card problems ) and I've been doing some research and it seems that the #00 Screwdriver which people recommend MIGHT strip the screws. Is this true? and if it is true what screwdriver should I use?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Alex, any screwdriver "MIGHT strip the screws". That is where the importance of good tools comes in. I prefer to use quality tools only, and invested in a set from here. The chances are slim to strip screws with the right set of tools.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
I used the smallest phillips screwdriver I had, and it worked fine but you have to press down firmly on them to make sure they grip tight enough without stripping.
Puan 2
Yorum Ekle
if it they arent coming dont force them. Apply a drop and i mean a tiny drop of oil (wd-40, pb blaster, trumpet oil, car oil, whatever). you need to let the drop of oil work in there for 20 seconds or so and try again. it is best to work the screw in and out meaning tighten and loosen it to get it free and even after its free you might have to tighten and loosen to work that oil in there. It will come out like this with patience
Puan 1
Yorum Ekle
Yanıtını ekle
Alex sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 533
