Ana içeriğe geç
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
No HSPA+ since teardown
A week ago the power button on my Nexus 5 got stuck. I would press the power button and the phone would behave as if I was holding down the button even though I wasn't. I watched some teardown videos on YouTube and opened up the phone, took out the motherboard and gently squeezed the power button connectors on the board. This seemed to have worked because the button is no longer stuck and the phone is working. However, I have not observed the H indicator on the signal icon since then, only the E. It doesn't matter what I set the preferred network type to and I know there is HSPA+ coverage in the area. Is it possible I damaged or disconnected an antenna when I opened the phone? I have noticed no other issues. EDGE is working as well as can be expected.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
11 Cevap
Filtre ölçütü:
En Yararlı Yanıt
On step 8 of the iFicit teardown you see the blue boxes indicated antenna spring contacts. Make sure they are pointed up enough that they make contact with the antenna on the back cover.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
They are making contact as far as I can tell. Since I posted I've also noticed that I'm getting poor signal quality indoors.
tarafından
Yorum Ekle
i managed to fix it. try resitting the 2 coax cables.
Puan 1
2 Yorum:
@fuhui94
please tell us how u managed to fix it?
coz im having the same issue... only EDGE is working... no HSPA+ at all...
i have reflashed roms and have tested all the possible settings but no success...
please elaborate us how u managed to fix this problem?
tarafından
This is what worked for me. Look at the picture of the board in step 10 of the ifixit teardown. There are two round connectors at the very bottom of the board, one on either side. When you take off the back plate there are two wires connected to each of these. One of mine wasn't seated properly.
tarafından
Yorum Ekle
It would be more helpful if you tell us the model of the phone and what network you are using.
Anyway, do a software reset to start with.
Puan 0
Yorum Ekle
Tom,
Why do you think factory reset should solve this issue ?
Thanks,
Sagi.
Puan 0
4 Yorum:
Some bad software settings probably locked the network preferences. Anyway it's just a standard procedure.
tarafından
I think I will reflash my device to Lollipop, hope it will resolve the issue
tarafından
I reflashed my device to Lollipop and problem wasn't resolved !
tarafından
I did the same. Didn't resolve my issue either.
tarafından
Yorum Ekle
I've the same issue...
Puan 0
Yorum Ekle
oh %#*@ me too. i realized i am stuck on edge
Puan 0
Yorum Ekle
@fuhui94
Puan 0
1 Yorum:
i face the same issue once again. but im gonna try to replace my antenna. i realized my antenna clip was flat after changing the battery. i think i've applied too much force and affected the clip. gonna buy a new antenna to replace it.
tarafından
Yorum Ekle
I have the same issue, but the issue was caused by me dropping the phone. I dropped it on concrete, the back cover popped open in some places, of course I was furious for me being so clumsy , i closed the back cover and put the phone back in pocket... 2-3 hours later I was on bus, took the phone out to surf the web or whatever, noticed EDGE indicator, I was confused cuz I was in a H+ area and this shouldn't have been happening. Got home I have a 3G zone there, but nothing. I downgraded to 4.4.4 from lollipop, didn't help, reflashed to 5.0.1 didn't help, I couldn't fix it. Sometimes in some places it gives me 3G or H+ but the coverage indicator is half greyed out, on EDGE it's always full. So I don't know what to do. I don't have warranty any more, I can't even RMA the device. Can anyone help? Will it be a good idea to replace coax antenna cables?
Puan 0
Yorum Ekle
In my case, I had to replace the device motherboard, replacing the antennas did not help.
Puan 0
Yorum Ekle
Re seating the small coax cable plugs (tiny little plugs on grey wires) that run either side of the battery fixed this problem for me. One of them became unplugged when I dropped the phone and the problem confused me for a week. Fixed now :)
Puan 0
Yorum Ekle
Hi, i have a same issue. I was re seating small wires and nothing changed. Then removing all antenna cables for testing, but result still same only full signal EDGE working. How can i resolve this problem?
Thanks.
Puan 0
Yorum Ekle
Yanıtını ekle
Shelly sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 25
Her zaman: 2,444
