Ana içeriğe geç
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Soru Tümünü görüntüle
Screen flickers then appears with a double ghost image?
This happens intermittently whether the machine is hot or not.
sometimes moving the display helps to restore the screen and remove the ghost image.
Has anyone seen this before? Is it the display unit or the motherboard?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like your system got a concussion!
It sounds like the LDVS cable connection on the logic board is having issues. Did you get your system wet? There maybe some corrosion on the connector and/or ribbon cable. The other possibilities, the connector is broken or the cable is bad.
Pop the bottom cover and do a good inspection around the LDVS cable connector does it look OK? If not take a few good hi-res pictures and post them here for us to see make sure they are in focus as are closeups of the area.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
melji sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,537
