How do I replace a Burnt Out LED?
Only some of the LED's light up, how do I replace the ones that do not work?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The LED's can be tricky to replace. In order to replace an LED you will need to separate the circuit board containing the LED from the rest of the device. Using wire cutters, you will need to clip the broken bulb off and then solder a new one into place. The link below will take you to a soldering guide.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 42
Her zaman: 1,590
