Ana içeriğe geç
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Soru Tümünü görüntüle
iMac Intel with vertical lines - Use a G5 Intel display?
Hi,
I have a white 17" iMac Intel (w/isight) that has colored vertical lines on the display.
My understanding is that it means the display needs to be replaced.
Does that sound right?
If so, can I take out the display from a 17" G5 iMac and put it onto the working Intel iMac?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
See this thread..
Can I replace a iMac Intel 17" LCD screen with an iMac G5 17" screen?
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Here is the direct connect link. Ralph
http://discussions.apple.com/thread.jspa...
tarafından
Yorum Ekle
It will never work. I took the lcd LM171W02 (TL) (B2) off my C2Duo Build 10K459, and put the lcd LM171W02 (TT) (A1) from my isight G5 build 9L319 onto the intel unit AND.. after a short burst of the fans - it would not power on. I pulled the lcd cable from the socket - and the C2D powers up. I return the cable into the socket and the C2D fails to power up. I put the G5 lcd LM171W02 (A4) (M1) from my other isight G5 into the C2D and once again it fails to power up after the short burst of fans. The G5 lcd differ from the intel lcd in their pin-out and the type of signals they send. There is a workaround here if your keen. Do any other LCD panels work with this iMac? Take note that only LM171W02 (TL) (B1) and LM171W02 (TL) (B2) LG phillips brand seem to work on the intel models.
Puan 0
Yorum Ekle
Yanıtını ekle
bsmith1 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 3,317
