Ana içeriğe geç
The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
46 Soru Tümünü görüntüle
How do I check to see if my valves are damaged?
My timing belt went out. A friend said if my valves are damaged it'll be more expensive than just replacing the belt. I want check to see if they are or not so I know for sure if putting on a new timing belt will be worth it.
Bu iyi bir soru mu?
Puan -1
2 Yorum
Hi
Same problem in my 1990 Honda accord ex 16 valves. How do I check for valve damage?
tarafından
What happened to your Honda? what engine size? what have you tried?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Nathan, to check the Valves you will have to remove the cylinder head. If the Valves got damaged then you nay also have issues with your pistons etc. If you need further information, give us the exact year and engine size of your Honda.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
A cylinder leak-down test should expose bent valves without having to pull the head. Buy or borrow a leak down tester, if excessive leak down is found, listen at the throttle body, the tail pipe, and the oil filler cap to determine if the air is going past intake valve, exhaust valve, or rings.
Puan 2
Yorum Ekle
Yanıtını ekle
Nathan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,289
