Ana içeriğe geç
The Canon Pixma iP3600 is a compact inkjet photo printer that weighs 12.3lbs and is 17.0”(W) x 11.7”(D) x 6.0” (H). This wired printer was released as part of Canon's Pixma series in 2008.
22 Soru Tümünü görüntüle
How do I unjam a paper jam in my printer?
I can see there is a paper crumpled up in my printer. How do I remove it without making it worse?
Bu iyi bir soru mu?
Puan 27
12 Comments
i can't get the small piece of paper out the printer's name is canon
tarafından
Thank you!! this was not in the online manual. I was about to give up hope and go to buy a new printer. I was so frustrated. I just could not get a hold of it. It had ripped. Thanks again!
tarafından
For most consumer models there will be only one sheet of paper threading through the machine at a time and a straightforward path from the paper feed to the output tray. In that case, you will want to search visually. Look to see if there are pieces of paper sticking out where you can see them. For larger commercial printers, where the paper path is more convoluted, you will need to consult the paper jam status message for hints of where to look.
If you not getting properly then call us at 1-888-924-2961 toll free number for solve issue paper jam.
http://canonprintersupportwefix.blogspot...
tarafından
My new cannon 3600 printer was working fine for a few days then it decided to injest about 8 pages at one time WHY ? and a paper jam occurred. I watched the onlnie video on how to pull it out gently but I can't pull out the paper as there is so much of it . I don't want to damage the printer. What now ? Do you have a Cannon repair person near Dublin Ireland ?
tarafından
how fo youremove unblock paper a canon pixma printer350 if you cant see it. or would it better just to buy a new one
tarafından
7 tane daha yorum göster
Yorum Ekle
7 Cevap
Filtre ölçütü:
Seçilen Çözüm
Try to flip your printer around (to the back of it) , it doesn't look like it can be opened but that'd be an arrow and just push in that direction and the backside will flip open and you can take out your paper jammed from there!
Bu yanıt yardımcı oldu mu?
Puan 26
24 Comments:
excellent. but unplug power first. for safety. thank you!!!!
tarafından
Thanks alot it genuinely helped!
tarafından
Thanks a ton...really helped :))
tarafından
thank you, thank you , thank you !!! So simple when you get good advice !!!
tarafından
I did get the piece of paper out, but the error is still showing?
tarafından
19 tane daha yorum göster
Yorum Ekle
first unplug the printer from power and wait for 1 min than restart the printer .
please don’t pull the paper out from a jam in the opposite direction this will create more issues .
just go check to make sure there is no loose paper stuck in loading tray .
you can also take out paper roller and clean paper roller using a cotton cloth .
for more steps visit How to fix-paper-jam-printer .
after all steps consider restarting the devices (printer , computer , and router )
thanks
Puan 2
1 Yorum:
Good advice. To be more specific, flip the printer so it is standing on its face where the Canon logo is (closing the paper drawer first of course( with the underside facing you. There is fat roller looking bit at the top with a large arrow, and a flange sitting behind the arrow. Push the flange in the direction of the arrow and it will open the back. There may be orange sticky tape closing the aperture which you need to remove..
tarafından
Yorum Ekle
To fix a paper jam, gently pull the paper out, pulling it through the rear tray or the output tray in the front. Then press the resume/cancel button.
For more information, please refer to this device's troubleshooting page.
Puan 1
2 Comments:
I took out part of a page but can't see the rest of the paper
tarafından
unless it is just so close to paper tray, this could do some damage. go around to back and see arrow. slide to left and yep, unplug machine and see paper able to get out easy.
tarafından
Yorum Ekle
gently pull it out , it often works
Puan 0
2 Comments:
I don't see in my printer HP #2645 any paper to pull gently but it's stuck in the jem
tarafından
I tried doing that but the paper ripped and the situation is worse
tarafından
Yorum Ekle
step 1. make sure no paper
step 2 paper jam sensor must correct position . flag sensor is free
Puan 0
Yorum Ekle
You can this problem by calling online printer support number Or resolve yourself by reading this blog : Printer Paper Jam
Puan 0
Yorum Ekle
Make beyond any doubt that the stuck paper is not under the FINE cartridge holder.
On the off chance that the stuck paper is under the FINE cartridge holder, move the FINE cartridge holder to the right edge or the left edge whichever is simpler to expel the paper.
When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it gradually to the right edge or the left edge.
Hold the stuck paper with your hands.
Pull the paper gradually not to tear it, then haul the paper out.
Ensure that all the stuck paper is evacuated.
Close the paper yield spread, then reload the paper.
Puan 0
Yorum Ekle
Yanıtını ekle
Olivia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 16
Son 30 gün: 99
Her zaman: 60,764
