Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
2193 Soru Tümünü görüntüle
Soru Kapandı
iPhone 4S not turning on anymore
My iPhone 4S is not turning on anymore, even when plugged into a wall charger.
It is not showing the apple logo and the battery is not even getting warm.
After using another logicboard it booted just fine without any problems.
What do you guys think is the problem with the logicboard?
Thanks in advance
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
What is the voltage on your battery connector when you plug it in? Check if there is continuity between the - and + on your battery connector.
tarafından
My connector was giving me 0 volts, so I looked at the schematics and after a while noticed the wifi chip had a short.
After replacing thhe chip my iPhone was starting up, but R49_RF and C13_RF are missing, and my U5 was getting veeeery hot, with the batteryconnector reading 4,05volts.
But after 1 day it would not become hot anymore and booted normally, but now the wifi is greyed out.
Has it something to do with R49_RF and C13_RF missing?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I would honestly drop it in an ultra sonic cleaner and then try it again. Or go to a shop and get liquid damage treatment.
Try It.
Also where do you live. If its in the SE of the USA defiantly try it. Good Luck!
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Well if you used another logic board in the same frame with all the same parts and it fired up and other logicboard dosent then it's definatly a fault with it
Puan 0
1 Yorum:
Yeah I tought that too.
But is there a way to find out where exactly the logicboard is damaged, because I am able to to micro-soldering, so maybe I can fix it.
I only don't know how and where to search
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 622
