Ana içeriğe geç
Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Soru Tümünü görüntüle
Why is my screen black after installing a new HD and RAM
I recently followed the steps for installing a new hard drive (the recommended 500gb drive) as well as new RAM (crucial 8gb, 2-4gb). When trying to power up afterwards, I hear my computer turn and it accepted my install disc but the screen remains black. I did unplug the battery during repair but plugged it back in. I did not notice anything break or go wrong while replacing. I appreciate any thoughts.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Double check the seating of the RAM and the HD cable. 99.044% of the time a reassembly issue is a connector (connection) that turned out to be lose or incomplete. Of course the RAM is 1066 MHz DDR3 SDRAM (PC3-8500).
Have you tried to boot from a different volume? If the HD is not formatted, and there's no OS on it you should at least get a grey screen - to install the OS and format the drive you will need a boot volume of some sort.
Connect an external monitor - if that works normally you have an onboard video chain problem (at lest the CPU/GPU logic board are OK)
If this answer is acceptable please remember to return and mark it accepted.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thanks for the quick response, I'm not going to have time to mess with it again for a few days but I'll give those things a try.
tarafından
Yorum Ekle
Yanıtını ekle
John sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 873
