Ana içeriğe geç
Soru Kapandı
I have damaged this component on the mother board (look). Any workaround?
Hi everyone. So I am kind of a brute when it comes to things in general, and I have managed to damage my MacBook Pro by acting like a smart @%^ and trying to fix stuff that wasn't broken.
As you can see from the picture the shielding from one component is almost completely gone. First it was only partially gone and it was working, but if the copper wire would touch other parts then the power adapter light would become dim and the computer not starting.
Now I have damaged more of the shielding after I cut a small length off the copper wire that was sticking out to prevent it from touching the neighbouring parts. This is probably where I did the dumbest move, now realising that the amount of copper might be crucial to the functioning of that component.
Anyway, if you guys can tell me what it is that I am looking at, the function, and if there is any workaround like coating it with something, I would greatly appreciate it.
Serial: C02FF6WUDF91
Bu iyi bir soru mu?
Puan 0
1 Yorum
2.2 GHz Core i7 (I7-2720QM)
Intro Date: February 24, 2011 Disc Date: October 24, 2011
Order No: MC723LL/A Model No: A1286 (EMC 2353-1*)
Subfamily: Early 2011 15" Model ID: MacBookPro8,2
Std RAM: 4 GB Std VRAM: 1 GB*
Std Storage: 750 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Alex, "after I cut a small length off the copper wire that was sticking out", not a good idea. That copper wire is urgently needed. The component is a coil (inductor and needs the copper wire. The whole component is part of your computers 3.425V supply. You will have to replace it or risk further damage and ultimately complete failure. The reference number for the part is L6995 and it is a 33UH-20%-0.44A-0.455OHM inductor. Not sure where you are located, but try Mouser or digikey for a replacement. You will need to solder it to the logicboard. So this will require good tools and skills to replace.
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
Thank you so much for your reply. This has certainly clarified a lot for me. Cheers :)
tarafından
I am writing again in the hope of acquiring a little bit of further assistance from you. Could you be so kind to link me to where I can directly purchase the exact component I am seeking? My own searches have not been so fruitful; also I stumbled over something that had the shape of a square not the circle which is in place on the MacBook Pro...
tarafından
This one has all the right specifications:
http://www.digikey.com/product-detail/en...
Is this the part I need? :)
tarafından
Looks like a BI technology HM66A-0520330MLF13 would be a perfect match. The shape is not quite as important as the package size. It has to fit between the solder pads. Get the BI technology datasheet from here and check the dimension between the contacts.
tarafından
It seems that it is only possible to order 3500 units as the minimum. :s
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 188
