Ana içeriğe geç
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
What causes gray screen and a repeating series of 3 beeps?
My intel-based iMac running 10.5 will not turn on. The startup tone is heard, then a gray screen, then a continuing series of three beeps. The response is the same even when the shift key, D key or T key are held at startup. Suggestions? The computer did not suffer any bumps or bruises.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
According to Apple this means that the RAM does not pass the test. There is a RAM DIMM in your computer that is defective. Please follow these directions to take out your ram. Start by taking out one, then starting up the computer. If it works, that RAM DIMM (or RAM stick) is defective. If it doesn't work then its the other DIMM, so reinsert the one you just took out, take out the other, and start up your computer again. In the unlikely event that it still doesn't work, it may mean that both DIMMs are fried and you need to order some ram and test it out with that. Your iMac has a maximum ram capacity of 6 GB.
Bu yanıt yardımcı oldu mu?
Puan 6
2 Yorum:
Here is the link for the beep code. Ralph +
http://support.apple.com/kb/HT1547
tarafından
iMacs have a different diagnostic set, why, I am not sure, maybe because it has no power light. http://support.apple.com/kb/HT2538
tarafından
Yorum Ekle
This worked! I had one bad RAM module. Thanks so much for the help.
Puan 1
1 Yorum:
If Gabes answer solved your problem, please Accept the answer so it can be archived for others.
Thanks
tarafından
Yorum Ekle
Worked for me, too. Just wanted to chime in with another confirmation. I got lucky and it booted after removing the first chip. Easily done.
Update
I should have noted that my fix was on a three year old MacBook exhibiting the same symptoms, not an iMac.
Puan 1
Yorum Ekle
This happen to my IMac (3 short beeps, 3 long beeps etc)
Apple wanted $500 to replace the logic board
I swap the pram battery and the iMac booted like a chame
Puan 0
Yorum Ekle
Had this problem. Suspect that I was using "sleep" instead of "off" too often. Now switch off regularly and. Problem not recurring.
Puan 0
Yorum Ekle
Yanıtını ekle
delamare1 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 14,735
