Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Soru Tümünü görüntüle
best tool for standoff screws - stuck standoff screws
Hi,
Been reading posts on the standoff screws and removal of the screws when looking to remove the logic board.
I have been using a small flat head screw driver to remove these however I have been coming across some extremely tight screws which when using this method, I end up spending a good 30-60 mins removing two screws as the force needed to move them means the flat head driver slips,
Does/has anyone come across this problem at all? is there a tool that people use specifically for these screws? i've read about grinding down a phillips screwdriver to make it flat to get a good ground in all four connections. what do people think?
Thank you
Danny
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here's what you need:
[bağlı ürün eksik veya kapalı: IF145-343]
Bu yanıt yardımcı oldu mu?
Puan 5
2 Yorum:
You can also buy a standalone driver with that same tip. I have one and it is lightyears better than using spudgers or flatheads. Its worth the couple of bucks to buy one.
tarafından
Hey! My standoff hex nut that I am trying to remove in my iPhone 6S is completely smooth! It does not have a slot for a flathead to fit anywhere. Any ideas?
tarafından
Yorum Ekle
Those things are extremely aggravating. I don't know why someone hasn't invented a screwdriver just for them
I have found the the round side of a metal spudger works really well when you have plenty of room and the pointed side works ok (better than a flathead screwdriver) in tighter spots.
http://www.mobiledefenders.com/metal-spu...
Puan 1
2 Yorum:
THEY DO! after a lot of digging around i found a screwdriver on ebay from china that is specifically for these stand off screws!! its incredable! best £10 i ever spent!
tarafından
I worked on one for about 10 minutes with all of the different flat head attachments that come in the fixit kit and could only get it off after seeing this post and using a metal spudger. Thank you!
tarafından
Yorum Ekle
If you use a bigger flathead screwdriver, you should get more pressure? Or find a flathead screwdriver with a bigget bit so that it fills up the track in the screw?
Puan 0
Yorum Ekle
I use the standard one you get in most repair kits and it works fine, just position it perfectly
Puan 0
Yorum Ekle
Yanıtını ekle
danny sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 81
Her zaman: 13,081
