My laptop not showing anything on display.
My laptop cannot show anything on the screen and the fan is not spinning but the power-led is on. What is the possible problem of this.
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
My screen is black and I do not have a fan sound
Bu yanıt yardımcı oldu mu?
Ditto! I have pulled out the memory, HDD, keyboard, hooked up to external monitor and nothing. When I power on, I get two LEDs on in the front, but I can see the fan doesn't move (because keyboard is removed). I am going to replace CMOS batt... maybe that is the problem?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 2,831
try an external monitor first and see if it shows anything.
oldturkey03 tarafından
Same problem. Black screen, no sound but fan noise. Both leds green.
I hope mobo is still alive. I'll try to reset BIOS removing little battery.
lillofiretto tarafından
Try re-seating the Memory. If the fan is spinning up abnormal loud try to re-seat the Cpu.
Goulithum tarafından
I have the same problem. It powers up with a blank screen, fan goes on, then suddenly it powers out.
Carlos Gardea tarafından
Ditto here. I see the fan is not spinning because I took the keyboard out. I have removed memory, HDD, plugged into external monitor... nothing.
Mike Caron tarafından
