Why is my flash not working?
The flash on my camera is not working and I can not figure out why.
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
You should try following this simple procedure to get your camera's flash up and working again. You will want remove the battery and memory card and reinsert both after a couple of seconds. You will then want to turn on your camera and place it on Auto Mode. Try seeing if the flash works now by pressing the shutter button on to take a picture.
Hope this helps!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,873
i am having same problem, could you find a solution?
123456 tarafından
