Ana içeriğe geç
Skullcandy Air Raid, 15 Kasım 2013 tarihinde piyasaya sürülen ve Bluetooth özellikli herhangi bir cihazdan müzik akışı sağlayan kablosuz taşınabilir bir Bluetooth hoparlördür.
Why wont my device charge?
I have checked my wall outlet and it works perfectly fine with charging other plug-in devices, it just seems to be a problem with my Air Raid. What should I do?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If the outlet is working and your device is still not charging, you may have a bad USB port. If your device only charges when the plug is held at a certain angle, will not plug in all the way, or has visibly bent/broken pieces inside the charging port, you should replace the USB port. If you have left the Air Raid charging for a long time, but the battery dies quickly after unplugging it, you may need to replace the battery.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
You should try going to Skullcandy Air Raid Troubleshooting for more troubleshooting help
tarafından
Where do i purchase a new battery?
tarafından
Yorum Ekle
@Sasha Nevin, SAME!! IDK what to do about it, but it is really annoying. I've had to use earphones (the ones u stick in ur ear) and was trying to get away from those, however it just won't charge! I also tried charging it through my computer, therefore it still didn't charge
Puan 0
Yorum Ekle
Yanıtını ekle
Sasha Nevin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 20
Her zaman: 5,380
