Ana içeriğe geç
Repair guides for the Motorola Moto G. A series of Android Smartphones manufactured by Motorola Mobility since 2013.
970 Soru Tümünü görüntüle
Only backlight after screen replacement?
I work in a cellphone repair store. I have been repairing Moto G screen with no issues as they are really easy. But I was changing one of the customer's screen today and the phone will turn on and makes boot up sound and the notification led blinks too but, I can't see anything except there is just LCD back light. I have compared the motherboard with a picture online in case I damaged tiny I.C components but everything looks fine.
Any help would be really appreciated,
Thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
isn't there a way to hard reset? had the same problem with a oneplus one
tarafından
Yorum Ekle
8 Cevap
Filtre ölçütü:
Hi, I have the exact same problem. Did you figure out what it was?
Thanks.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Hi! I replaced my screen as well a while ago and had the same problem. Turned out i forgot to flip back the little switch located at the part where the screen connection plugs into the rest of the phone. Hope that helps!
Puan 0
1 Yorum:
Thanks HelpingHand! I tried that and it didn't work. I really don't know what else to do!
tarafından
Yorum Ekle
change lcd it will work for me
Puan 0
Yorum Ekle
The flex connector probably got folded during installation causing it to crack slightly leading to break in circuit.
I think you need to replace it again if nothing else works.
Did you come up with a solution ?
Puan 0
Yorum Ekle
i have this problem can u solve them?
Puan 0
Yorum Ekle
Try to hold the power button for 120 seconds while it is connected to a charger. (Yes, two minutes.) I am not sure if it wipes all your files, I remember it doesn't.
Puan 0
1 Yorum:
tnx i try this and also 120sec power+down key and nothing just black screen
while rom is up every thing is work i get screenshot and connect phone to pc and see screenshot file and all is ok just screen in black
tarafından
Yorum Ekle
I have the same problem... I changed the screen it was working fine but i forgot part of earphone; hence i disassembled and assembled again... now screen doesnt work!
help please....
Puan 0
Yorum Ekle
Have the same problem. Not flex cable as I have tried two different screens and have the same problem with both. Phone is powered up and running but at first had the blinking white light which I understand to be the dead battery light. It worked fine the first teardown then once a new screen went in neither of them worked. What else ?
Puan 0
Yorum Ekle
Yanıtını ekle
osheanjuneja sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 3,419
