pry damage solder a wire or replace component
hello all.
i have a iPhone 4s from a customer, it has a some pry damage (he tried to place a new screen)
now i replaced some 0603 and 0402 components.
but this little black block i don't know.
is it possible to solder a wire on the pads ?
or do i have to replace the component, but what component is this ?
thanks in advance
Update
anyone that can tell me if i need to solder a wire or not
thank you
Bu iyi bir soru mu?
6 Yorum
roy, we can not see what you see. Post a couple of images with your question. Adding images to an existing question Show us the components you replaced as well as the "little black block"
oldturkey03 tarafından
thanks oldturkey, seems because i was on dutch i couldnt edit my post or place pictures.
thanks
roy tarafından
hey Oldturkey,
i posted the pictures, can you tell me if i can solder a wire across or if i need to resolder the component
thanks
roy tarafından
can someone tell me
or if you need a differnt picture also tell me
thanks in advance
roy tarafından
I never advocate jumpers. I figured the Apple engineers had a plan with all those parts. Replace them with proper components.It is a Zener diode and check st3v3w's schematic for the proper values.
1 tane daha yorum göster
