Ana içeriğe geç
Küçük, 15 watt'lık bir pratik gitar amfisi olan Fender Frontman 15r için onarım kılavuzları. Model numarası: 022-1500-000.
changing to a premium speakers
was wonder how high of a wattage speaker the frontman can support the spec on the amps says 38 quess that's peak output? it's a 8 ohm speaker
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
2 Yorum
I Tried A 8inch, 200 Watt "Crate Custom Design" Speaker In Mine. Hasn't Fried Yet. Then Again I Also Hooked It Up To My Fender Twin's 2 Speakers. What The !&&* It's A Cheap Amp, If It Blows Who Cares! By The Way, You Can Get A Celestion Eight 15 8" 15W Guitar Speaker 8 Ohm. New On Ebay For $29.00 With FREE Shipping.
tarafından
For Chits & Grins, I Hooked Up My Fender Frontman 15g To My Fender Twin's 2 Speakers. The Little Bastered Sounded Quite Good!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The only thing to worry about is if the amp will kill the speaker, no worries of speaker killing amp in this case. You can run anything 8 ohms that is rated 15W or higher. Given that guitarists like to torture speakers, I might look for a 25-35W speaker just to make it more bomb-proof. If you are buying a speaker for it, there's not much point in going higher than 50W unless you plan on reusing it in some other (higher power) amp later on. The much higher power speakers generally won't be as efficient at lower power levels.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
burnoutfun sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 1,965
