upgrading battery from 2800 mamp to 3200 mamp
is i can upgrade a battery with more power for my tab ?
Ex: 2800mamp to 3200 mamp ?
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Mohammed Buhari sure you could if you can find one that fits your XTouch. Be aware of the scam with higher capacity batteries etc. Most of those are not any better than the standard batteries. You can try and search for a better battery based on the physical size of yours as well as the connector. Check reputable sellers only. Check this The myth of the "high capacity" batteries since it is still true today. Remember, higher capacity batteries also take longer to charge
Bu yanıt yardımcı oldu mu?
Now Why? How do you upgrade a Battery’s MAH
IS A BAD IDEA TO DO IT!
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 201
