I dont know this part, is it a SMD Tantalum Capacitor?
I have and macboook pro i5.
3 of (22 1e20) are broken.
What component is this?
Where can i buy new one (ebay?)
I have searched the web but no clue.
Thank you
Bu iyi bir soru mu?
Thank you
Bu iyi bir soru mu?
FD, all three capacitors are 22UF 25V 20% Poly Tantalum Capacitors in a D2 case
Bu yanıt yardımcı oldu mu?
D2 is a 7343 case with the 7.3 X 4.3 X 1.9mm dimension. So, those that you picked do not appear to fit sizewise. Something like a Panasonic 25TQC22MV should work for you. Also, remember that there is a reason those caps blew up. Make sure that you determine the cause of that. It most likely is not just a matter of replacing the components, try to determine what happened.This one http://www.ebay.nl/itm/PANASONIC-25TQC22... would work.
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 446
1 Yorum
FD add some images first Adding images to an existing question
oldturkey03 tarafından
