Ana içeriğe geç
Repair information for tools used for specific tasks like fixing, building, or cutting. Learn how to use tools that work to fix the ones that don't.
2233 Soru Tümünü görüntüle
Soru Kapandı
Some one using TI EV2300 to program/hack a Battery back
TI EV2300 is a tool to program BQ series battery gauge.
I'm considering to get my A1185 out of "Permanent Failure" using EV2300.
Some one ever tried that or have some info/suggestion?
Thanks!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
did you check the lipo cells first? are the fuses ok? - if a battery fails - it's most likely the problem of the cells and not the pcb inside the battery
so checking the voltage of every single cell and their fuses would be my first step - but that involves disassembling the battery (be careful and don't bent the cells)
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
'cause i'll replace the cells and the g**d*** "self destructive" fuse. and i know what i'm doing.
just need some tool to reset BQ20Z80 status.
i don't know if this can be done by just programming SMBus...
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 2,783
