Ana içeriğe geç
Bu, 2011 yılında Canon tarafından üretilen bir kompakt fotoğraf makinesidir.
Why am I getting a Lens Error?
When I turn the camera on, the lens stays extended and the LCD screen displays "Lens Error/Will shut down automatically/Restart now." I've tried turning the camera off and on again but the error still displays. When the camera is off, the lens remains extended.
Bu iyi bir soru mu?
Puan 3
2 Yorum
See more suggestions below - lens assembly replacement almost always works.
tarafından
Sometimes, the lens mechanism can get stuck or misaligned. With the camera turned off, try gently tapping or shaking it (not too forcefully) to see if it helps free up any obstruction or realign the lens. Be careful not to apply excessive force or impact that could further damage the camera.
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
This is a known error with the Canon PowerShot S100 camera. For more information, you can visit Canon's press release here or you can attempt to fix it here.
Here is a link to our troubleshooting section about this issue.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Replacing the lens assembly will almost always fix this error if simpler fixes don't succeed. See my guide for the process here: Canon PowerShot S100 Lens Assembly Replacement.
Puan 1
Yorum Ekle
Canon will not fix my camera because of rust and corrosion. I am warning people not to send their camera back. They are trying to get out of actually fixing the situation by forcing an out of warranty repair. I barely used this camera so I know that the rust and corrosion is not something I caused.
Puan 0
1 Yorum:
If Canon won't fix it, go with this place. They have serviced multiple cameras for me and they are excellent (about half the price of Canon).
This is who I used: www.camerasandparts.com
Good luck with the problem
tarafından
Yorum Ekle
remove the battery. close the terminal. hold the on/off button for 1 minute. replace battery. turn on and use.
Puan 0
1 Yorum:
your solution doesnt work
tarafından
Yorum Ekle
I fixed my Canon PowerShot S110 with the vacuum cleaner. I turned on the vacuum, placed the hose over the lens, turned the camera on and off and hooray . . . it worked! Good luck fixing yours. Kathie
Puan 0
Yorum Ekle
Yanıtını ekle
Ricky sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 113
Her zaman: 35,956
