Ana içeriğe geç
4th Generation Apple AirPort Extreme Base Station (Model Number A1354)
wan port not detecting internet provider
my airport extreme suddenly stopped working. I can get internet through the ethernet cable direct from provider modem to my computer but not through extreme. I have tried reset and factory reset with no success. The LED indicator on the WAN port indicates it is working but no provider is being detected. If this is a hardware problem does anyone know of a possible repair.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
2 Yorum:
What does Apples AirPort Utility tell you?
tarafından
Did you get things working?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Apple AirPort Extreme is a simple fix, it is either the antenna or the WiFi card.
if the WiFi light is on it most likely to be an antenna, you can get one off ebay for pretty cheap
here is the guide to fix replace it.
Apple AirPort Extreme Model A1354 Antenna Replacement
if you need to replace the WiFi card, here is the guide for that.
Apple AirPort Extreme Model A1354 WiFi Card Replacement
Apple AirPort Extreme Model A1354 Antenna Görseli
Kılavuz
Zorluk:
Orta
5 minutes
Apple AirPort Extreme Model A1354 WiFi Card Görseli
Kılavuz
Zorluk:
Orta
10 - 15 minutes
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
wmathie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,196
