Ana içeriğe geç
Released in January of 2013 the Canon Powershot, model number A2500, is a 16 Megapixel digital camera. This camera can be used to take images or low quality videos.
8 Soru Tümünü görüntüle
How do I delete all images on an SD?
I want to wipe the SD, but I don't have a connector to plug the SD on a computer. I prefer not to have to delete the images one-by-one on the camera. Is there a way to delete all data on an SD? If so, please help.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Victoria,
In order to wipe your SD from this model camera you must turn on the camera with the SD Card correctly inserted and then press the menu button. Then scroll to the right so that the wrench and the hammer tab is now highlighted. Now scroll down to "Format..." and select it. The menu will now prompt you to format the memory card, press OK twice and your memory card will be wiped.
For any further issues visit our Canon PowerShot A2500 TroubleShooting guide. Where there are guides for several other common problems.
Hope this helps,
-James
Bu yanıt yardımcı oldu mu?
Puan 13
7 Yorum:
what does scroll to the right mean? What or where am I supposed to scroll?
tarafından
James, Thanks so much for explaining how to erase images from camera. It worked perfectly for me on my first attempt. SUPER EASY! (Once you know how) lol
tarafından
How do you press the "OK" button?
tarafından
How do I take a picture without using the flash please?
tarafından
What do I need to do if the "format" section is not highlighted like the other selections and does not respond to clicking on it? Victoria
tarafından
2 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Victoria Winters sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 49
Her zaman: 18,603
