Can I fix my review button?
The review button on my Camera will no longer work, this is the second camera of this kind that has had the same problem. I can no longer review my pictures. Is this a common issue?
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
This can be a common issue in many cameras. Buttons tend to worn due to bouncing the key so much. Also, the buttons can become sticky due to residue underneath the keys. Make sure you do not store the camera in particularly dusty, humid, or high temperature conditions because this can have adverse effects on the electrical contacts of the button switches. You can try to reset the camera to the factory reset, putting everything back to the way it was the day you took the camera out of the box. If that fails, you can send your camera back to the manufacturer to get the button replaced and to make sure there is no further damage to the keys. Hope this helps!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 429
