To be honest with that curved line in the LCD, I would say your LCD is cracked. That black area on the side looks like "bleed". I would examine the LCD through the glass. If you shut the tablet off or put it to sleep so the screen is dark, you can take a flashlight and look for cracks. Hair line fracture will tend to show up with a flash light or even in a very well lit environment. Sometimes looking at the screen from different angles helps to. If you don't see and fractures you can try to reseat the connector. Though it looks like the LCD is damaged to me.
You can try to locate parts for that tablet. I would say try ifixit.com or eBay. Your going to look for a display assembly. This will be both digitizer and LCD. You can also look here as well as YouTube to see if you can find a how to as far as replacement. If it looks like something you don't want or can't do, try a local repair shop. They will give you a quote and you can determine if you want to repair or replace.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
2
10 Comments
me to so i banged it it worked for 2 mins then went like that angin
sbine wren tarafından
my dell tab 7 white display missing in ic
ravi tarafından
tablet fell off my hands and some colored lines on the side someone help me!!!!
Faithlynn Aguilera tarafından
How do I fix my amazon fire
makenzie yarnell tarafından
I was wondering the same.
InternetIsRequired MSP tarafından
5 tane daha yorum göster
