Black Spot on pictures
1/2" square black image appears on Lcd Monitor and in pictures. It looks like a piece of dirt on the lens but it will not wipe off, it must be on the inside.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
We had an issue like this with one of the cameras here. Sure enough, as Majesty has said, it was a small speck of dirt on the sensor. Compressed air is a fine solution. They also make a cleaning solution for cameras for just this purpose as well.
Bu yanıt yardımcı oldu mu?
I would carefully open the camera up and clean the insides with compressed air. You might have dirt or other small debris on the sensor. Don not try to wipe the lens, most likely the debris is inside of the camera.
yes
clean the sensor(CCD)
10000% clear ur fault
i have clear this fault many time
Keep up the repair solutions, but please do not post contact information to advertise your personal business. Thanks!
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 5,023
1 Yorum
It looks like you solved your own problem right there in your question, they just confirmed your solution. :)
Taylor Arnicar tarafından
