Ana içeriğe geç
The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
Black Spot on pictures
1/2" square black image appears on Lcd Monitor and in pictures. It looks like a piece of dirt on the lens but it will not wipe off, it must be on the inside.
Bu iyi bir soru mu?
Puan 2
1 Yorum
It looks like you solved your own problem right there in your question, they just confirmed your solution. :)
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
We had an issue like this with one of the cameras here. Sure enough, as Majesty has said, it was a small speck of dirt on the sensor. Compressed air is a fine solution. They also make a cleaning solution for cameras for just this purpose as well.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
En Yararlı Yanıt
I would carefully open the camera up and clean the insides with compressed air. You might have dirt or other small debris on the sensor. Don not try to wipe the lens, most likely the debris is inside of the camera.
Puan 3
Yorum Ekle
yes
clean the sensor(CCD)
10000% clear ur fault
i have clear this fault many time
Puan 0
1 Yorum:
Keep up the repair solutions, but please do not post contact information to advertise your personal business. Thanks!
tarafından
Yorum Ekle
Yanıtını ekle
Ron Skelly sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 5,022
