Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Soru Tümünü görüntüle
Black Screen after display replacement
I replaced my iphone screen what caused actually a problem that no matter which display i place in (old and new one) it only shows up a blackscreen. I did everything like in the tutorial here but something happened that destroyed my phone !?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
sounds like you've blown a backlight filter on the logic board. Look at your replacement screen---if you see three solder lines on the smaller backlight flex on the screen, then those should be covered with tape. Some low quality screens have these exposed. Once installed, if the exposed backlight solder joints touch the frame it will short the backlight voltage to ground essentially blowing a fuse on the motherboard.
You'll have to send it out for board repair.
Other possibilites are damage to the LCD connector itself.
jessa
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Hey thanks for your expert answer ;D But I actually really dont know what a backlight flex is so I looked on the whole display assembly for three solder lines but I couldnt find one. Does it help to know that my computer still recognizes my iphone ? Maybe that could help to exclude a cause for that problem :(?
What I also called im rememberance that I installed my old screen with the flex cables and I checked if the display is working fine before I attached the whole screen into the case. But suddenly after the whole attachment the black screen problem appeared :(
tarafından
Yes, it is either backlight or connector. Either way, send it out for a board repair.
tarafından
Yorum Ekle
Yanıtını ekle
kiggoin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 167
