Ana içeriğe geç
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Engine WIll not crank
Craftsman riding mower engine will not crank. Installed new battery and still will not crank.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 11
4 Yorum
Is the mower turning over at all or is it just a dead mower?
tarafından
turning over backfires thru carb
tarafından
adjusted air gap valves set gap on coil
tarafından
after I changed my blades incorrectly the pgt9000 would not start with the switch. I can jump the solenoid and it will crank and run . I changed the switch and the solenoid , but still have to jump the solenoid. I think there is a relay that blows if the blades aren't on correctly, but I can't find it.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Are you getting any response when you turn the ignition? If not, it may be your starting solenoid or spark plug. Both are sold as replacement maintenance parts at most retailers who carry lawn and garden supplies.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Pamela sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 9
Her zaman: 1,762
