Engine WIll not crank
Craftsman riding mower engine will not crank. Installed new battery and still will not crank.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 10
Her zaman: 1,763
4 Yorum
Is the mower turning over at all or is it just a dead mower?
Nathan Wells tarafından
turning over backfires thru carb
allenperkins364 tarafından
adjusted air gap valves set gap on coil
after I changed my blades incorrectly the pgt9000 would not start with the switch. I can jump the solenoid and it will crank and run . I changed the switch and the solenoid , but still have to jump the solenoid. I think there is a relay that blows if the blades aren't on correctly, but I can't find it.
meriview@aol.com tarafından
