Ana içeriğe geç
Xiaomi akıllı telefonu tamir kılavuzları için *doğru* yer.
Xiaomi Mi phone not reading the sim card
Hi,
I have Xiaomi Mi phone and last night I dropped it, since then it isn't reading the sim card. I tried the below steps still it isn't working, please help.
1) Rebooted the cell phone.
2) Took out the sim and inserted it again.
Thank You.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
4 Yorum
hi,
showing no sim card
i have reset my mi4i and it had showing green box and i thing software has been blocked so i flashed MIUI 7 in my mi4i and i updated it using package downloaded from mi but it is showing no sim card i want the reason for what happened
tarafından
hi,
not reading my sim card
my mi9 is not reading my sim after the latest update from miui10 to miui11 .
im wondering if there's a soluyion to ths issue?
tarafından
my redmi 10 not showing only second sim
tried interchanging sim card
tried another simcard
tried factory reset
but stil not working
one more thing im not getting option to enable or disable simcard
i was using redmi 3 s prime and now i feels redmi 3s was much better then redmi 10
many other optins are unavailabe
i advice not to buy redmi 10 not because of i have sim card issue in my mobile
but because there are many options are unavailable and it is very difficult and irritating to handle on one hand because of its size.
tarafından
@jairamraut Try Xiaomi built-in hardware test https://xiaomiui.net/hidden-hardware-dia..., you should be able to tell if SIM card reader is working or faulty
tarafından
Yorum Ekle
11 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi, just insert a paper below your sim and it will detect. You also dont need to shut down the phone.
Bu yanıt yardımcı oldu mu?
Puan 7
5 Yorum:
Redmi 4x speaker not working, what can I do about it
tarafından
it worked for me on a mi max 2 , signed up to say many thanks XD
tarafından
Worked for me too. Xiaomi Redmi3. Thank you very much!
tarafından
Man. U r the Messiah ! Jus signed up to say Thanks. It worked ?for my Redmi Note 5 !
tarafından
No its not working after 6 hours, sorry u r not the messiah ! :(
tarafından
Yorum Ekle
Hi everyone ,wanted to ask i insert 2nd SIM in mi a2 , network has been recognized but there is no signal . could anyone help here in this regard
Puan 2
Yorum Ekle
I have got new Mi4i yesterday. But, It can't detect my sim card
Puan 1
Yorum Ekle
it seem like your logicboard has drop damage. There is two pins in your phone that connect to tell the phone you have a sim inside might no longer be there. so when you put the sim in the phone the phone will not start to read the sim.
Unfortunately Xiaomi phones are very uncomment out side of asia and there is no parts for it.
Puan 0
1 Yorum:
My mi4i Sin tool kit not showing in display please tell me how to recovery
tarafından
Yorum Ekle
Redmi 3 sim-2 not reading
Puan 0
Yorum Ekle
Guys this time its a much bigger issue. Xiaomi are working on it and hope to push a fix out before the end of the week. The issue only applies to vodafone Mi9 phones. Check this out. https://www.theregister.co.uk/2020/05/14... I have also spoken to Xiaomi customer support.
Puan 0
Yorum Ekle
If the SIM card is not being detected by the phone anymore there may be 2 reasons why, first reason is that when it was dropped a cable that runs from the phones main circuit board to the SIM card tray has fallen off or has a loose connection. Most newer phones have the SIM card slots part of the main circuit board. In which case it is possible that when you dropped the phone you may have damaged the pins on the SIM card slot. If you do have dual SIM card slots on your phone I would recommend swapping the SIM card to the other slot. Also if you SIM card is an older card, you may want to contact your carrier for a replacement SIM card
Puan 0
Yorum Ekle
My sim 1 lock please
Puan 0
Yorum Ekle
My sim Not run SIM card
Puan 0
Yorum Ekle
My dual sim is not detected even after made several steps like phone reboot, network reset, airplane mode and reverse to normal mode etc....But the surprise is that the sim card was not detected only after updated the software 12.5.10?????
Is there any solution for this?
why these errors are not been highlighted before purchasing this comp[any mobile??
Puan 0
Yorum Ekle
Olradi of my sim card permanent sim open now
Puan 0
Yorum Ekle
Yanıtını ekle
gagandeep kaur sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 48,354
