Dual hard drive doubt
Hi, Greetings!
I intend to add a second hard drive in my iMac 21.5"mid 2011, actually a 480GB SSD OCZ Vertex 460A and I have three questions:
- Vertex 460A has an outer metal casing. Could this be a problem, because of static electricity or possible contact with iMac components?
- When I put back the optical drive in its bay, there could be a risk of touching the bottom of it at the top of the SSD? I am thinking about the possibility of vibrations of the optical drive when working to damage the SSD.
- What about the temperature when the optical drive is running, the heat could damage the SSD?
The best solution to the health of the SSD would not simply remove the optical drive and put the SSD in its bay?
Thanks a lot and best regards.
Bu iyi bir soru mu?
